Coupon: MTG01
Save: 10USD
Coupon activity Time: 14th Jan 2019 - 30th Apr 2019
Only need: $252.99
More information: http://bit.ly/2SYR8Ld
Main Features:
♦ Instant Hot Constant Water Temperature: Once start washing, fresh water source is heated to constant temperature and remained constant state for a longtime wash to save energy.
♦ Comfortable Feminine Cleaning: With one nozzle on the side rim for cleaning the anus and genital areas, helping female to clean their vulva easily and keep healthy even in the menstruation period.
♦ 4-grade Adjustable Water Temp: Easy to customize your optimum water temperature, seat temperature and washing pressure.
♦ Cold-hot Massage Washing Function: Cold water and hot water massages your body by turns to relax your skin and improve partial blood circulation.
♦ Hip Wash Back and Forth: Press the "Hip Wash" button again, the nozzle will move back and forth constantly to expand the washing area, improving the cleaning effect.
♦ Standard External PP Cotton Filter: Coming with a PP cotton filter, it effectively filters out more than 20 microns of impurities such as sand, dirt, rust and worms, providing more hygienic washing water than bathing.
♦ Dual-self-cleaning Nozzle / UV Sterilization: Before washing, the ringlike flow will clean the nozzle thoroughly with UV light automatically killing the bacteria on the nozzle when the user is away from the toilet seat.
♦ LED Nightlight Illumination: Convenient for night use, without disturbing your family
♦ Full Body IPX4 Waterproof: Splash-proof in full range, safe and reliable for daily use.
♦ Safety Protection: In emergency of electrical leakage, the plug will auto shutdown.
