M9S PRO 3gb ram 32gb storage - 5.1. docooler - apps fail error is for using vm os instead of a tablet os.
    Currently experiencing an issue with this device m9s pro 3gb 32gb android 5.1. All the apps I use. think its a vm/virtual machine device.
    I have been able to test with other boards and appears theres some details that maybe not set in ui?
    Please help.
    Would like this box to perform the same as the other boxes. Have tested nexsmart 4k. And works well with my apps. the apps run because they think its on a tablet or tablet os.
    But apps fail on m9s pro because apps think they're running on virtual machine.,
    would upgrading to 7.1 complete the ui or is there a way to edit the ui to appear like a tablet so the apps run. I have other devices I've tested that are ok and appear as a tablet
    hey need the firmware the m9s pro 32gb
