Beelink J45 Mini PC - Pentium J4205 Processor, 4GB RAM 128GB ROM
    The new Beelink J45 128GB integrates a Pentium J4205 processor, a quad-core chip manufactured in 14nm with a maximum speed of 2.6GHz and a graphics processor Intel HD 505 reaching 800MHz, allow you to enjoy Windows 10 without any problem thanks to the good overall performance. The RAM memory is 4GB LPDDR4 and includes a SSD MSATA 128GB. There is also a free bay for a 2.5 inch disk with SATA3 connector allows easy storage expansion. It has a dual HDMI output with which you can mount a system with two monitors.
    Main Specifications:
    CPU: Intel Apollo Lake​ Pentium J4205, Quad Cores, 1.5GHz up to 2.6GHz, Cache 2M
    GPU: Intel HD Graphics 505
    RAM: 4GB DDR4
    ROM: 128GB mSATA SSD
    Max Extended Capacity: TF card up to 64GB
    WiFi: 802.11 b/g/n/ac 2.4GHz + 5.8GHz dual-band WiFi
    LAN: 1000M
    Bluetooth: 4.0
    Decoder Format: H.264, H.265
    Internal Connector : MSATA SSD, MINI PCIE, SATA HDD
    Language: Multi-language
    Learn more about it: https://gearvita.com/beelink-j45-min...128gb-rom.html
    Hot sale products:
    q50 kids gps smartwatch
    qcy t1c mini wireless earphones
