[Firmware Stock] H96 MAX X2 4GB/64GB, 4GB/32GB and 2GB/16GB TV Box.
    AS Found Not tested:
    H96 MAX X2 TV Box
    Note: This firmware is suitable for H96 MAX X2 4GB/64GB, 4GB/32GB and 2GB/16GB TV Box.
    PC Flash Firmware
    Flash Tool
    Flash guide, please refer to: http://blog.geekbuying.com/index.php...tv-boxes-flash tutorials-tool/
    Have fun!
    The post H96 MAX X2 Amlogic S905X2 Android 8.1 TV Box Firmware Update 20190114 appeared first on .
    blog.geekbuying
    Update change log as X96 Max...
      I have a H96 max box and accidently deleted the browser and as a result the play store in not working so please how can i reinstall a browser to download apks
      frustrated.
        This ROM works well
        XTM_ATV_X96_4_4_to__H96MaxX2_4GB-only.7z
        Other then the OK button doesnt do anything when on keyboard screen if anyone know how i can fix that would be great
          No update.zip or ota method?
            Originally posted by uscool View Post
            This ROM works well
            hello my have h96max x2 4gb 32rom
            how will this software be installed
              This probably the best image i found
              [ROM] POISON TV H96_MAX_X2 V3.1 Changelog V3.1 -Nov 2 2019 Released -Based on Beelink 906P0 Firmware -AndroidTV Version -Stock Recovery -Optimized Systemui -Overclocked Gpu -Tweak System -Fixed Iptv reboot issue -Fixed Glitch in ui -added even more remote layouts:) -Fixed conflict of tweaks i had in previous versions -Poison
              Follow this how to flash
                thank you
                I tried the first one negative, device does not install
                I haven't tried the second one yet
                my device has lpddr3
                  what is latest best firmware for H96 MAX X2 4GB/32GB ?
                  Thank you
                    Originally posted by bundyboy View Post
                    Thank you
                    i am currently testing spartan rum, it works better than official rom
                      ok. can you tell me do you know what could be a problem with USB_Burning_Tool, and what version I need to have ? v2.1.6 ?
                      as it does not detect the box ?
                      i click start, and then i connect the box with usb cable, and after that i connect it with power cable...
                      but it does not detect the device.
                      is this correct order ?
                      do i need to connect it with power cable also or ?
                      also can spartan rom work on my box: s905x2_8ddr3_v02
                      Thank you
                        Thank you
                        Hi, always try to use the latest USB Burning Tool, I guess it's v2.2.8?
                        The way to connect to PC is, insert a toothpick or something similar into the AV port, you should feel a reset button pressing. Keep it pressed while inserting the USB cable in the USB 2.0 port (Black port, not blue) and wait until it gets detected by PC and shows in USB Tool as Hub connected then let go of the reset button and firmware will flash.
                          Thank you
                          sorry i have always updated with the SD, for me it is easier
