The Teclast F7 is a budget/entry level laptop powered by the Intel Celeron N3450 (Apollo Lake) quad-core. With 6GB of LPDDR3 RAM and 64GB of fast eMMC 5.1 spec storage. It?s got a 14.1″ 1080p IPS glossy screen with a matte anti-glare protector on it and the base build and design of it is from the same ODM as the Jumper EZbook 3L Pro.
Price: $309.99
Link: http://bit.ly/2B2Ibtn
The laptop weighs only 1.32 kilos and under 14mm thin. The full metal body is made of a lightweight. On the underside, you?ll find an SSD hatch that lets you add a M.2 2242 SATA3 spec SSD to expand the storage up to 512GB.
Thanks to a 9W power limit and great cooling with a large copper heatsink the Teclast F7 performs well. Best of all if you go into the bios which is unlocked by the way, disable that power limit you?ll boost that performance even further.
Overall the Teclast F7 is a fantastic laptop for the price when you look at just what you?re getting it?s hard to imagine it selling for as low as $310 sometimes.
Price: $309.99
