I dont know English.
I will try to explain my problem with google translation.
my h96 max + 4/64 RK3328 is plugged in on the start screen. When I looked at the recovery section, the following error appeared,
Supported API:3
E:Failed to clear BCB message : failed to fsync/dev/block/platform/ff520000.dwmmc/by-name/misc: I/0 eror
I tried to install .img with factory tool, usb burnnig tool and android tool, but gave the following error;
download İBD Fail.
how to fix this problem.
Thank you in advance for your help.
