How do you update the Alfawise Z1 box?
    Alfawise Z1 TV BOX 2.4G Voice Control - Amlogic S912 Android 7.1 3/32GB
    How do you update this box? Is there a hidden toothpick method. Mine won't do the burn card maker or the usb burning tool. Thanks.
    Found it...?...There is a tiny hole on the back of the box for a pin to fit.
