Nextbook ?
    Nextbook ?
    Hi guys, here in BRazil Yifing products come with the Brand Tectoy, i ahve the Build.prop of mine but i cant check de Serial and cant find a similar model... i want to cook a rom and fix a problem wich the tablet turn off when in sleep mode... someone can give me a little help ? Thx
    here the build.prop
    # begin build properties
    # autogenerated by buildinfo.sh
    ro.build.id=IMM76I
    ro.build.display.id=V2.0.0.IMM76I.user.root.201303 26
    ro.build.version.incremental=eng.root.20130326.110 316
    ro.build.version.sdk=15
    ro.build.version.codename=REL
    ro.build.version.release=4.0.4
    ro.build.date=2013年 03月 26日 星期二 11:04:52 CST
    ro.build.date.utc=1364267092
    ro.build.type=user
    ro.build.user=root
    ro.build.host=ljgong
    ro.build.tags=release-keys
    ro.product.board=TECTM757ND_T
    ro.product.cpu.abi=armeabi-v7a
    ro.product.model=Next7D12
    ro.product.brand=TT-2501
    ro.product.name=TT-2501
    ro.product.device=TT-2501
    ro.product.cpu.abi2=armeabi
    ro.product.manufacturer=YIFANG
    ro.wifi.channels=14
    ro.board.platform=meson6
    # ro.build.product is obsolete; use ro.product.device
    ro.build.product=TECTM757ND_T
    # Do not try to parse ro.build.description or .fingerprint
    ro.build.description=TECTM757ND_T-user 4.0.4 IMM76I eng.root.20130326.110316 release-keys
    ro.build.fingerprint=MID/TECTM757ND_T/TECTM757ND_T:4.0.4/IMM76I/eng.root.20130326.110316:user/release-keys
    ro.build.characteristics=tablet
    # end build properties
    # system.prop for M1 reference board
    # This overrides settings in the products/generic/system.prop file
    #rild.libpath=/system/lib/libreference-ril.so
    #rild.libargs=-d /dev/ttyS0
    ro.sf.lcd_density=160
    keyguard.no_require_sim=1
    #set keyguard.enable=false to disable keyguard
    keyguard.enable=true
    ro.statusbar.widget=true
    ro.statusbar.button=true
    ro.statusbar.yearmonthdayweek=true
    #wifi.interface=ra0
    # Time between scans in seconds. Keep it high to minimize battery drain.
    # This only affects the case in which there are remembered access points,
    # but none are in range.
    #wifi.supplicant_scan_interval = 60
    #alsa.mixer.playback.master=DAC2 Analog
    #alsa.mixer.capture.master=Analog
    #configure the Dalvik heap for a standard tablet device.
    #frameworks/base/build/tablet-dalvik-heap.mk
    dalvik.vm.heapstartsize=5m
    dalvik.vm.heapgrowthlimit=48m
    dalvik.vm.heapsize=256m
    hwui.render_dirty_regions=false
    # Disable un-supported Android feature
    hw.nopm=false
    hw.nobattery=false
    hw.nophone=false
    hw.istablet=true
    hw.novibrate=true
    hw.has.accessibility.accel=false
    hw.cameras=1
    hw.hasethernet=false
    #hw.hasdata=true
    ro.platform.has.touch=true
    # Wi-Fi sleep policy
    ro.platform.has.sleeppolicy=false
    #set to 0 temporarily so touch works without other changes
    ro.sf.hwrotation=270
    #0~7 You are required to get the correct install direction according the sensor placement on target board
    ro.sf.gsensorposition=1
    ro.sf.ecompassposition=4
    allow_all_orientations=1
    # Set Camera Orientation
    # Use OSD2 mouse patch
    ro.ui.cursor=osd2
    ro.hardware=amlogic
    # Enable 32-bit OSD
    sys.fb.bits=32
    # Disable GPS
    gps.enable=false
    # Enable player buildin
    media.amsuperplayer.enable=true
    media.amplayer.enable-acodecs=asf,aac,m4a,ape,flac,alac,wav
    media.amplayer.enable=true
    media.amsuperplayer.m4aplayer=STAGEFRIGHT_PLAYER
    media.amsuperplayer.defplayer=PV_PLAYER
    media.amplayer.thumbnail=true
    # Nand write need force sync when gadget
    gadget.nand.force_sync=true
    # Status bar customization
    ro.statusbar.widget.power=true
    # HDMI
    ro.hdmi480p.enable=false
    rw.fb.need2xscale=ok
    media.amplayer.osd2xenable=true
    #camera DCIM dir. 0:sd only; 1:nand only; 2,sd first
    ro.camera.dcim=1
    # Disable preload-class
    ro.amlogic.no.preloadclass=1
    # App optimization
    ro.app.optimization=true
    # CPU settings
    ro.has.cpu.setting=false
    # For 800 x 480
    ro.platform.UI.800x480=false
    #ro.platform.has.mbxuimode=true
    #support media poll uevent,can use sd cardread on usb port
    has.media.poll=false
    # gsensor board
    ro.7inch.gsensor=1
    ro.8inch.gsensor=0
    #For Erase internal SD card
    hw.erase.internalSdcard=true
    # CPU freq customized in setting menu
    # normal, performance, powersaving
    ro.cpumode.maxfreq=1200000,1512000,800000
    # when usbstorage, CPU mode and freq
    ro.usbstorage.cpumode=performance
    ro.usbstorage.maxfreq=600000
    #audio effect
    ro.audioEffectEnabled=true
    #Dual display
    ro.vout.dualdisplay2=true
    ro.vout.player.exit=false
    #Encrypt tablet
    #ro.platform.has.security=false
    #hdmi settings
    ro.hdmi.has.settings=false
    #used forward seek for libplayer
    media.libplayer.seek.fwdsearch=1
    #enable address bar cover issue fixing
    ro.flashplayer.surfacehack=1
    #used to set default surface size, set 1 when hwrotation is 270;
    #enable widevine
    media.amplayer.widevineenable=true
    media.amplayer.stopbuflevel=0.002
    #YF prop
    ro.yifang.devicename=TT-2501
    ro.yifang.hotpoint=0
    ro.keyguard.orientation=landscape
    ro.yifang.bluetooth=1
    virtualsd.enable=true
    ro.yifang.weather.city=New@York
    ro.yifang.weather.isf=0
    ro.yifang.unknown.sources=1
    ro.yifang.default.timeout=600000
    # ADDITIONAL_BUILD_PROPERTIES
    ro.opengles.version=131072
    ro.config.notification_sound=OnTheHunt.ogg
    ro.config.alarm_alert=Alarm_Classic.ogg
    drm.service.enabled=true
    ro.setupwizard.mode=DISABLED
    ro.com.google.gmsversion=4.0_r4
    dalvik.vm.dexopt-flags=m=y
    net.bt.name=Android
    dalvik.vm.stack-trace-file=/data/anr/traces.txt
    ro.hardware.version=1.0.0.0
    ro.vendor.name=YFMID
    And one major problem, the wifi turn off when charging because of the temperature =/
