Teclast is one of the most popular Chinese tech companies that is focusing on making high-quality tablets, laptops, and other products. The latest addition to its laptops line is the Teclast F7 Plus, which is currently available for purchase at a price tag of $399.99 from coolicool.
Only need: $399.99
More information: http://bit.ly/2TjRcW3
Teclast F7 Plus adopts all-metal fuselage design. The surface of the fuselage is treated with a similar grinding process, which makes the fuselage feel delicate.
It uses micro-arc design around the A side, and CNC trimming and polishing at the edge, commonly known as diamond cutting process. The effect is very good. Moreover, such treatment is not confined to the surroundings of the A side, including the C side and the touch panel all have similar treatment. At this point, Teclast F7 Plus seems very attentive.
The Teclast F7 Plus is a 14" Gemini Lake Intel Celeron N4100 powered laptop with 8GB of DDR4 2133Mhz RAM. It' has a 128GB SATA3 SSD, USB 3.0 ports x 2, Wireless AC, MicroSD reader, 3.5mm headphone jack.
The battery is 38Wh and a full metal build with a glass covered non-laminated 1080p IPS screen. The keyboard is edge to edge and is backlit. The Teclast F7 Plus runs Windows 10 Home. The laptop is 7mm at its thinnest point and about 1.6 kilos.
Only need: $399.99
