Hello, need help to flash my android box H96 pro + I receive an error message as indicated on image attached, please help me ...
H96 pro+ error
If you have the proper firmware for your device....- USB cable that is long can cause trouble.
- Disable antivirus software.
- Run USB Burn Tool as Administrator.
- Uncheck "Erase BootLoader"
- If that fails you may have to keep holding in the reset button. (Someone mentioned just tapping reset button @ 2% error mark???)
- Try again.
There are currently 2782 users online. 0 members and 2782 guests.
