[SOLVED] Jesusrun DX05 bricked after low level format. Need original firmware.
    I need to flash the original firmware.
    When I tried to flash the K-R42 hybrid rom, using the upgrade option of Rockchip flashtool, I've bricked the system. Not only I couldn't upgrade to K-R42 rom, also the flashtool applied a low level format, so I cannot boot now...
    So, any one can send me the original Jesurun Dx05 firmware?
    Best Regards
    you should press restore button not upgrade.
    Everything is possible if we work together!
    ApkFreak
      The restore returns error:
      23:26:08 879 **********Restore Start Total<1>**********
      23:26:08 881 <Layer 2-1-1> Test Device Start
      23:26:08 883 <Layer 2-1-1> Test Device Success
      23:26:08 885 <Layer 2-1-1> Lowerformat Device Start
      23:26:20 901 <Layer 2-1-1> Lowerformat Device Success
      23:26:20 904 <Layer 2-1-1> Test Device Start
      23:26:20 908 <Layer 2-1-1> Test Device Success
      23:26:20 911 <Layer 2-1-1> Check Chip Start
      23:26:20 916 <Layer 2-1-1> Check Chip Success
      23:26:20 919 <Layer 2-1-1> Get FlashInfo Start
      23:26:20 922 <LAYER 2-1-1> INFO:FlashInfo: 0 0 0 1 0 20 20 28 1F 1 1
      23:26:20 925 <Layer 2-1-1> Get FlashInfo Success
      23:26:20 932 <Layer 2-1-1> Prepare IDB Start
      23:26:20 934 <LAYER 2-1-1> INFO:CS(1) (8192MB) (TOSHIBA)
      23:26:20 950 <Layer 2-1-1> Prepare IDB Success
      23:26:20 956 <Layer 2-1-1> Download IDB Start
      23:26:21 662 <Layer 2-1-1> Download IDB Success
      23:26:21 666 <Layer 2-1-1> Reset Device Start
      23:26:22 671 <Layer 2-1-1> Reset Device Success
      23:26:22 676 <Layer 2-1-1> Wait For Loader Start
      23:26:24 377 <Layer 2-1-1> Wait For Loader Success
      23:26:24 383 <Layer 2-1-1> Test Device Start
      23:26:24 388 <Layer 2-1-1> Test Device Success
      23:26:24 393 <Layer 2-1-1> Download Firmware Start
      23:26:29 617 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=1048576,write=79872
      23:26:34 818 Error:RKU_ClearBuffer-->totalRead=0
      23:26:39 821 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=1048576,write=85504
      23:26:45 022 Error:RKU_ClearBuffer-->totalRead=0
      23:26:45 023 <LAYER 2-1-1> ERROR:RKA_File_Download-->RKU_WriteLBA failed,Written(1048576),RetCode(-3)
      23:26:45 024 <LAYER 2-1-1> ERRORownloadImage-->RKA_File_Download failed(kernel)
      23:26:45 030 <Layer 2-1-1> Download Firmware Fail
      23:26:45 034 **********Restore Done Success<0> Fail<1> Time<36146>ms**********
        try flashing my 1.2.0 hfw and post back
        ApkFreak
          Problem solved. The solution was to use the microusb cable that came with my nexus 4.
          Somehow the microusb cable that I used on the first case was not able to download firmware to my jesurun dx05 (although I had a green box on the batch tool?).
          With the new microusb cable I was able to successfully install your 2.0.4 hwf and I am loving it so far.
          Thanks.
