[ROM] DietPoisonATV S905X (RedPoison "Fork")
    Many thanks minixfreak for his release.
    I made some modifications on that rom since it was the only which suits to my 1/8 glx p212 glx platform device without changing anything.
    Anyway I decided to lightly debloat and make some changes to PoisonATV because I like it more conservative.
    What is done:
    removed:
    pre-installed apps
    talkback
    hindi, japanese, pinyi, korean, Zhyuin IME
    Music2Pano
    fonts NotoSansCJK-Regular.ttc
    NotoColorEmoji.ttf
    some ringtones
    some alarms
    some notifications
    bootplayer
    Build.prop:
    Wifi channels=13
    Region=ALL
    Changed:
    Changed wallpaper
    Changed bootlogo
    Changed Bootanimation (instead of bootvideo)
    I really appreciate any help or contribution since I am not a dev....
    To be modded:
    colors, background of v2 when getting back to homescreen (Poison Team - just tell me :-P )
    Available MODS:
    RedPoisonATV_V1_S905X_1GB_classic_ATV_Soldiaz_FINA L.img 916MB
    RedPoisonATV_V2_S905X_1GB_classic_ATV_Soldiaz_FINA L.img 893MB
    Request Google Drive link through pm...
    reserved
      Does the Pip feature work in your version? The red poison one doesn't work on my x96 (but the ATV version did work)
        ill fix soon i have an idea whats going on
          Since I was contacted by PoisonTeam due to copyright I would like to make clear that I just modified an existing image. I chose the name not in order to present my own built image but to make clear that it is a RedPoison derivate.
            thank you for the great work i have the same device, but how do i download it? i use chrome browser
              Originally posted by soldiaz View Post
              Finished.
              Themed to original ATV, bit "debloated", red stripe is left.
              After clearing all that up I'd like to upload the image..
              they cannot put copyright on this, i am a data analyst and I know how copyright works. the google apps are all google's property and the rom is tanix's property. if they tell you that they own things in it then it should be the wallpaper, bootanimation and logo. anything other than that is either falsely claimed or breaking real copyright infringement. you can even release the rom as your own and nobody can put copyright as long as tanix and google don't mind.
                To avoid stress....
                Just little modifications:
                re-themed to classic
                replace bootvideo , bootlogo
                remove apps
                remove Fonts
                remove notification etc... audio
                200mb reduction
                  Id love to try these out. Can I get the links in my inbox?
                    hey is this rom google play protect certified.
                      ? guess not
