With powerful Qualcomm Snapdragon 845, OnePlus 6 draws on the increased power and efficiency of Qualcomm?s latest chipset. The speed you need in a smartphone comes not only from raw processing power. It?s about how to use this speed to make life easier. A combination of intelligent software and powerful hardware ensures a performance that keeps the same high speed as life. Right now Oneplus 6 (8+128GB) available on CooliCool For Just $479.99
Only need: $479.99
Link: http://bit.ly/2E3tI2l
Much of what makes the OnePlus 6 feel special is its completely new build and design. It?s now made almost completely of glass that curves around the rear and feels fantastic. There?s a rim of metal sandwiched between the glass to add some rigidity too.
There?s been a switch-up in other classic OnePlus design aspects, too. The alert slide is still present, but it sits on the opposite side and the fingerprint sensor is now an oblong shape, perched beneath the centrally positioned dual cameras.
OxygenOS is a refined version of Android and is optimized for speed thanks to the efficient use of memory and lightweight applications. The faster the phone, the smoother experience. With updated Gaming Mode 2.0, the amount of data assigned to apps running in the background automatically reduces the amount of data assigned to the game you play when enabled. Release layers and increase your chances to win against your friends. Release the reading pad and turn on Reading mode. Grayscale is added while blue light is filtered out to provide a reading experience similar to an e-reader. Right now Oneplus 6 (8+128GB) available on CooliCool For Just $479.99
Only need: $479.99
