For example with app smart iptv (https://siptv.app/news/) it freezes after around 20 minutes. With halva tv player it takes around 4 hours. Also with smart iptv there is visible stuttering. (fps drops)
I have tried changing display resolution to 1080p50. (the channels that i watch use 1080p25). I only want to use this device to watch full hd iptv. I could even install linux if this could help.
I have also tried https://www.atvxperience.com/ rom, but it didn?t helped.
With coreelec, libreelec or alexelec it?s even worse than android. It has visible stuttering (fps drops) and it freezes just after 5-10 minutes. (even when using 1080p25 resolution)
I tried using usb drive, sd card. Installed with rufus, Win32DiskImager. It still has same issues. I guess there is something wrong with amlogic codec on this device. When i tried to run non hd channels it seems that there is no stuttering.
Maybe i should try different dtb? I always use gxl_p281_2g
Maybe my x96 mini has updated hardware and the dtb is created for older version?
