Only need: $309.99
Link: http://bit.ly/2TMWeup
Armor 3T also is a revolutionary mobile phone with interchangeably intercom, which supports 1W/2W hardware intercom (400-470MHz). Meaning, this phone did not relay on any software to realize this function, it?s true offline intercom. The operation range is up to five kilometers1.
Besides, it works well with common inter phones as along as you share the same frequency band. Armor 3T shall be your partner that you can count on since you will be connected no matter if there is signal or not. Walkie-talkie function makes you stay in touched with others even in the jungle, desert, rainforest, on the sea or mountain.
Certified to highest IP68/IP69K rating, it can handle 2 hours of immersion in 2 meters of water or 24 hours of submission in 1 meter of concrete. Meanwhile, it can also withstand big drops up to 1.2 meters. No matter how hard the condition is, with water-resistance, dust- resistance, shock-resistance, Armor 3T will protect himself all round and then standby your side to support you. Thanks to the IP68 protection grade, Armor 3T will survive under many circumstances, especially in tough conditions. It also means extra wide applications for you.
Ulefone has included a fingerprint sensor on the Armor 3T too, which it has placed on the right-hand side of the device below the power button. The volume buttons sit on the opposite side above the walkie-talkie button. Ulefone has hidden the microSD and two nano-SIM card slots behind a metal panel on the back of the device, which requires undoing four Torx screws to remove.
The Ulefone Armor 3T is a solid mid-range smartphone that is good enough for daily use and is also suitable for the harshest of environmental conditions. The Armor 3T has a sufficiently bright display. The IP69K certification is currently a rarity for smartphones too, which gives the device the edge over some of its competitors. The dedicated radio antenna works well too and is another unique selling point of the device.
Only need: $309.99
