I have a H96 pro + with failure in the power stages. The tv box just worked a couple of hours and went out, giving these cues.
I have already checked the transformer, and it had the capacitors defective, which are already changed.
Now I am reviewing the motherboard, and I have detected that it is failing in the power stages, and I can not find exact references to know what it might be.
Attached photos with the values of volts wich the boardis showing.
Somebody could help me?
Thanks in advance.
Pic with volts (all values are with reference to ground):
Pic where you can see the ICs:
