Xbox 360 controllers do not work on all Android TV roms (xpad)
    JohnWayne compile correct driver :
    s905x2_xpad.zip
    extract and put it in /system/lib/
    load: insmod /system/lib/xpad.ko
    I tried the xbox360 controllers on these rom:
    [ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
    On BEELINK GT1 mini 4gb ram 64gb rom
    u need xpad.ko compiled for ours u211 kernel 4.9.76 - it doesn't exist
    sorry, i need it too
      You don't need a module when it's built-in kernel
        u sure?
          Originally posted by JohnWayne View Post
          u sure?
          Guessing kernel config is correct I'm quite sure.
          Code:
          u211/sbin # zcat /proc/config.gz | grep XPAD
          CONFIG_JOYSTICK_XPAD=y
          CONFIG_JOYSTICK_XPAD_FF=y
          CONFIG_JOYSTICK_XPAD_LEDS=y
          Moreover we were at least 2 to confirm it working. But don't ask me why it doesn't work for you and OP.
            JohnWayne do you have a box gt1 mini 4gb ram 64gb rom?
              Yes, and i use xtmod atv v3. Wired xbox doesnt work. My bluetooth ipega9076 works. Tried magisk 1controller module - doesnt help.
              Code:
              u211:/ # zcat /proc/config.gz | grep XPAD
              CONFIG_JOYSTICK_XPAD=m
              need module xpad.ko
                s905x2_xpad.zip
                i compiled correct xpad.ko
                  It works!!! You are the best my friend.
                    Can i use it on supercelerom atv rom i tried connecting my xbox wired controller but it doesnt work the light just blinks
                      Yes!
                        Yes!
                        Thank you can you tell me hiw to do this load: insmod /system/lib/xpad.ko. sorry m new to all this
                          Install Termux on Playstore and launch
                          su
                            Hi All,
                            I have test XTMOD ROM (Version V4) on X96 Max (2 Gb version, not support Bluetooth) with Tronsmart Mars G02 gamepad (using 2.4 Ghz USB wireless) but it not working.
                            Can you tell me how to fixed this issue?
                            https://www.tronsmart.com/products/t...ame-controller
                            And I also trying download the zip file on your link, but not success when using Termux app: failed to load xpad.ko: Invalid argument
                            https://forum.freaktab.com/filedata/...7&d=1556893233
                              Originally posted by thelinhlge View Post
                              Hi All,
                              This driver is made for xbox360 controllers
