Minitv Andriod
    Minitv Andriod
    hi.
    Please help I have a minitv for andriod with a dual core A9processor. Until yesterday it was running fine but came home
    dont know what the kids had done!! but it started up but was stuck in load up screen with andriod showing?
    So i did a bit of research as kids were driving me up the wall. I found out that it was a firmware problem and had to clean it up and load new software. After some more searching I found my self at this site!
    So off I goes and installs "finless 1.6 rom for mk808 tv player. by bob" Execellent tutorial and detailed every
    step.
    All is good and the device boots up and goes into home screen. But there is one problem my wifi and bluetooth wont come on? I have been into settings and select wifi on, it attempts to start search for devices but then turns it self off stright away. The same with bluetooth
    sef
    Thats because you installed a firmware for another stick . Maybe your stick is a clone and you confused it for a original one.
      Thanks for the reply. I had installed wrong firmware it was for m808, my stick is m808b loaded fin v1.5 for m808b. Problem solved. But video pixel a little squarely on action moives need to find a way to solve!?
      Sef
        Sef
        What player are you using? Try MX Player. Also install MX Player Codec (ARMv7 NEON).
