Is there a setting on this box that I can tweak to make it work with the HDMI switch ?
No output through HDMI switch
I have an AMLogic S912 based android TV Box (T96 Pro) that works perfectly when connected directly to the TV. However, I have other devices sharing the HDMI line through a Kinivo 501BN HDMI switch and when I connect this box to the switch, there's no output to the TV at all. Other devices connected to the switch have no problem and I have verified that there's nothing wrong with the cable or the HDMI port. I have tried enabling/disabling HDMI CEC as well, but it made no difference.
Is there a setting on this box that I can tweak to make it work with the HDMI switch ?Tags: None
Originally posted by yyzyyz View PostI have an AMLogic S912 based android TV Box (T96 Pro) that works perfectly when connected directly to the TV. However, I have other devices sharing the HDMI line through a Kinivo 501BN HDMI switch and when I connect this box to the switch, there's no output to the TV at all. Other devices connected to the switch have no problem and I have verified that there's nothing wrong with the cable or the HDMI port. I have tried enabling/disabling HDMI CEC as well, but it made no difference.
did you set the Resolution on TVBox right , what is the highest output of the switch ,
best to set Box to stock 1920*1080 60fps ,
i use one , 5 to 1 , until now but , already bought a , 6 to 2 , but must still be connected ,
please report / good luck / gefattern
Originally posted by yyzyyz View PostThanks for the suggestion, but 1920*1080 / 60 is what it's set to by default and the switch definitely supports that resolution (other devices are using the same setting).
maybe a Problem with the EDID , there must be Devices that can handle this , saw something in the Bay ,
There are currently 2034 users online. 1 members and 2033 guests.
