Possible rom 4.1.1 on minix neo x7 ?
    hi , i want know if it's possible ? it's more stable and work so much on minix neo x5 why not on x7 ?
    Thank You
    Anything is possible, but is it likely someone will make a 4.1.1 rom for the X7? I wouldn't hold my breath. As far as stable, yeah, that's pretty much a matter of perspective, but doubtful. The stability of a rom is not based just on the version number but rather on how the rom works in conjunction with the hardware and whether or not it was optimized for said hardware in the first place. As there was never a 4.1.1 for the X7, which has different hardware than the X5, your statement of stability is not only unfounded but more than likely incorrect. 4.1.1 ran like crap on some hardware and perfect on other hardware, so instead of looking backward and hoping for a frankenstein rom of 4.1.1 to run on hardware it was not designed for and therefore would more likely be even less stable than 4.2.2, lets just focus on trying to make the current version more stable on hardware it was designed for in the first place.
