Razor
Need Advice
Need Advice
Hi all, newbie here needs some advice. I have a MXQ pro 4K 4.6GB storage S905x Build p212 userbug6.0.1, purchased in 2016. Have been reading a lot and was just wondering, what I can do to speed this up or what to update to. Will not run new Kodi 18.1. Any help would be great or point me in right direction. Unit still works for Netflix, or should I just purchase new one> would like to try and work on this, Thanks.
RazorTags: None
Originally posted by razor07 View PostHi all, newbie here needs some advice. I have a MXQ pro 4K 4.6GB storage S905x Build p212 userbug6.0.1, purchased in 2016. Have been reading a lot and was just wondering, what I can do to speed this up or what to update to. Will not run new Kodi 18.1. Any help would be great or point me in right direction. Unit still works for Netflix, or should I just purchase new one> would like to try and work on this, Thanks.
Razor
the only thing you can do is try one of the several S905X Roms that exist here , but
before read & ask in the specific Thread if it will work with your Box ,
good luck / gefattern
There are currently 2721 users online. 0 members and 2721 guests.
