Thx u!
Please, I need help with h96 pro+ | I had a power outage while I was flashing a rom
Hi, I need help. I was flashing a rom with an SDCard and I had a power outage in my house! Now, when I put in the power cable, It turn on the blue led, but It don't show anything in the TV. What can I do to fix it? Please, I need help!
Thx u!Tags: None
Your China Box is most likely "Bricked".
Take a read how to "Un-Brick":
I had a question I hope someone could help with. I have an H96 Pro Plus box the CPU is a S912 3GB RAM 32GB of storage. It is bricked and one other post
You will have to open the box and see which type of PCB/NAND your box contains.
Great that you have connect success!
You may have to start with a basic firmware(original) to..set your box right, before advancing to a newer firmware.
If successful with original firmware, try to make a TWRP back-up before experimenting with other firmware.
I think (Shonk) here in the forums had a firmware to recover form similar situations.
I can't find the direct link in our forums. Try browsing the S912 root forum or the Alfawise forum. If I run across the link I will post in a day or two...
Finally, I could install the firmware with USB Burning tool. I had to try a lot of times. This firmware didn't finish, the software stopped the installation at 97%-98%: "aml_7.1.2_s912_q9377-H96PROPLUS_mac-20180409_shmod-k4-stockbl"
However, I used it: aml_7.1.2_s912_q9377-S912_mac-20171010
Thanks u!
hey there brand new to the forum. and i have the exact same problem. i bought it secondhand and the guy said he flashed it and the power cut,now ive tried the sd card method and ive tried the nand bridge/short method and still no luck, ive got the ddr4 version (CZ-S32-V3(DDR4)) and im at a loss, the blue light is static and the reset button doesnt seem to be doing anything,
The cpu is cold to the touch so i am assuming its not even trying to boot,
Ive got the samsung 246 LKMBG8FE4B-B001 nand, its got the pinout for the other flash type of memmory and i tried the nand method but ive read conflicting things like pin 29/30 and 15/14
is there somthing im missing
Also the usb cable i used was 2 standard micro usb chargers that i snipped and soldered together, this shouldnt matter right as usb_burning_tool_v2.0.9 isnt picking it up or even the general windows input ding
i cant really find much information on these as whole
i currently have a h96 pro+ blue board 2016-12-15(a15)
*no video and and the button does nothing
*i made a whole thread on this maybe people could avise there Very Sorry for hijacking someone elses threadLast edited by nintendogamer12; 02 April 2019, 17:29.
Originally posted by FNPCMDs View PostFinally, I could install the firmware with USB Burning tool. I had to try a lot of times. This firmware didn't finish, the software stopped the installation at 97%-98%: "aml_7.1.2_s912_q9377-H96PROPLUS_mac-20180409_shmod-k4-stockbl"
Thanks u!
Maybe it helps to reach 100%
There are currently 2502 users online. 5 members and 2497 guests.
