VARGO ZHUOYUE 3 VX3 is recently released by VARGO and its increasing aggressively in the market. The smartphone comes with a quality design and great features. The VARGO ZHUOYUE 3 VX3 is an absolute stunner targeting those on a tight budget. It?s powered by the Helio P20 chipset, 6+128GB and sports dual rear camera for photography. Currently, the VARGO ZHUOYUE 3 VX3 (6+128GB) is available at CooliCool which costs only $129.99
Buy a mobile phone now, give away a free Bluetooth headset
Only need: $129.99
Link: http://bit.ly/2U9Mxqf
The VARGO ZHUOYUE 3 VX3 is built around a 5.7-inch HD+ IPS LCD full view display. The screen boasts of 720 x 1440 pixels in resolution along with a 282 pixel per inch density for clear visuals as well. Overall, the screen stretches up to 78.41% screen-to-body ratio.
VARGO ZHUOYUE 3 VX3 runs on Android 7.1 Nougat out of the box. Running the race here is the Helio P20 chipset from MediaTek which comes with 8-cores of processor clocking at 2.39GHz offering a smooth ride. The ARM Mali-T880 MP2 GPU handles everything graphics. The phone packs 128GB internal storage space for storing your files, you can expand up to 256GB using a memory card. It comes with 6GB RAM space for multitasking through apps and tasks.
There?s a rear fingerprint scanner on top of that. While the dual rear camera is seen at the top left corner in a horizontal position. It measures 8.3mm in thickness, weighs 165g and is available in only Red, Gold, and Blue. Powering up the VX3 is a 3500mAh battery capacity with support for fast charging. Charging the battery from 0% to 100% shouldn?t take up to 2 hours.
The VARGO ZHUOYUE 3 VX3 sports dual 13MP + 13MP rear cameras for all your photography needs. The camera is equipped with a dual-LED flash and other internal features listed in the table below. For taking selfies, there?s an 8MP selfie shooter for that.
You can find this amazing VARGO ZHUOYUE 3 VX3 (6+128GB) in the CooliCool.com at a price of $129.99 with an incredible discount.
Only need: $129.99
