MK808?
    MK808?
    I'm new here and I am a total noob.
    I have mk808 MINI PC and I want to put a custom rom in it. Reading the forum I see that it can`t be entirely backed up, so I wonder where can I find the original ROM`s/Firmware . Or maybe someone knows where I can find stock rom for my device.My fiemware is : Android version 4.2.2 , Kernel 3.0.36+ rjh_V_301j2 #30 , Build version mk808_v303j2.
    I would like if its possible to save the rom from the device...
    Is there somewhere instructions for beginners how to dump mk808 stock rom/firmware with win7?
    Help please
      Help please
      Install this http://www.freaktab.com/showthread.p...rk3066-devices then you can backup rom to a microSD card.
      There are also lots of stock roms for mk808 on this forum, geekbuying.com and other forums like armtvtech.
      Also use this custom rom http://www.freaktab.com/showthread.p...0730)-_Sep2013 and follow the instructions to replace kernel for MK808 device. Read both threads completely and you won't have trouble.
        Thank you mo123
        If I understood the CWM can backup the whole rom with the kernel and system settings, but with it the partition can not be resized.
        With the stock recovery only the stock recovery can be backuped, by flashin a new one...
        And mk808b ROMs can be flashed into mk808 but afterwards a kernel for mk808 must be flashed, with rkflash tool.
        Ad the Finless roms iclude a stock recovery...
        Correct me if I'm wrong or add if I forgot something ...
