4GB+64GB / 4GB+128GB / 8GB+128GB For your reference.
Intel Apollo Lake Pentium J4205
Pentium J4205 is a quad-core 64-bit x86 desktop microprocessor. It is manufactured on a 14 nm process. The chip operates at 1.5 GHz with burst frequency of 2.6 GHz and has a TDP of 10 W. This GPU incorporates Intel's HD Graphics 505 GPU operating at 250 MHz with a burst frequency of 800 MHz.
Windows 10
It is pre-installed with Windows 10 home so that our users are able to enjoy the advanced functions of Windows OS directly. Moreover, the built-in Cortana in Windows 10 can turn Beelink J45 into a work assistant as well as life-partner.
2.4G/5G Dual Band WiFi
With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data.
Gigabit LAN
Gigabit LAN provides a data rate of 1 billion bits per second.
BUY NOW!
