I was wondering which firmware did you use to revive your box, I am in the same position and cannot pass "Prepare IDB Fail".
Failure Messages when Shorting the NAND chip and forcing MASKROM mode
I just tried every version of every program I could find to try to install the stock firmware with the same result.
plus whatsapp
project free tvLast edited by freakzstrop; 20 November 2023, 13:42.
The device doesn't boot. After shorting the pins on the NAND, the computer recognizes it as MASKROM. So I assume SD flashing is out of the question?
hdstreamz apk
krnl.fun
I want to thank you so very much for all your help gefattern, because it was you that made me question and inspect EVERYTHING.
projectfreetv.onl
waplus
There are currently 1380 users online. 0 members and 1380 guests.
