The Doogee S90 simply does more. Its revolutionary module design creates a mobile experience like never before. It all begins with four powerful specialty modules that expand the core functions of a smartphone. With the S90, you can go further, accomplish more, and power your adventures longer.
Limited time offer: $299.99
Activity time: March 4th to March 10th
Link: http://bit.ly/2C1ZZoY
The S90 transforms into a professional night vision camera simply by attaching the cam module. The night vision camera module is specially designed to absorb a greater range of light waves and algorithmically optimize them to improve image detail and accuracy. The process makes it possible to capture incredible shots in low light or backlight conditions.
Power for days. Adding the 5000mAh extra power module instantly turns the S90 into a 10050mAh battery behemoth. It provides enough juice for two-days of non-stop outdoor use without re-charging.
No signal? No problem! Talk to your friends without the need for network coverage, even in remote areas. The S90 intercom module covers a wide range of 400-480MHz frequencies for reliable off-grid communication for outdoor adventure. Never be out of touch.
Get your game on anywhere, with accurate control, easy installation, and super portability. Add the professional gamepad module for an upgraded mobile gaming experience that includes an ultra-responsive joystick and zero delay buttons to elevate your gaming and help you win. Just how tough is the S90? It?s designed to meet military specs and operate in the most challenging of outdoor and heavy duty environments. It meets or exceeds MIL-STD-810G specification tests of temperature & transport shocks, humidity, mold, salt spray corrosion, explosive gas, vibration, ballistic shock and more.
Should you buy the S90? The answer is unequivocally yes.
Currently DOOGEE S90 is being pre-sold in coolicool.
