Amlogic S912 /3GB RAM+32GB ROM / 2.4G+5G WIFI / 1000Mbps / HDMI2.0 / VP9 / H.265 / Supports HDR10 And HLG HDR
Description:
The Beelink GT1 Ultimate featuring the latest processor. It is equipped with the Amlogic S912 CPU which enables you to have a smooth entertainment experience. It also has a 3D noise reduction filter.
Main Features:
● Amlogic S912 CPU with octa core is rapid and stable, it can give you a high-speed feedback and smooth response.
● It has Passed Google Certificated and With Voice Remote Control , Support Netflix 4K .
● Dual Band WiFi: 2.4G plus 5.8G can improve the speed which can implement multitask.
● 1000M LAN can improve the net speed and the performance to a large extent.
● H.265 and VP9-10 Profile-2 decoding will offer you high definition pictures and movies.
● It owns the 3D noise reduction filter which is convenient for you to enjoy the high-quality entertainment.
Remarks: The remote control is shipped without a battery, and the customer needs to use 2 7 batteries.
https://www.gearbest.com/
