T95Q WIFI 5G
    T95Q WIFI 5G
    I buy a T95Q box, work all ok, but only a problem, the Wifi 5Ghz not work, i try to find network, but only found 2.4ghz network...
    I read on amazon user then write similar problem...
    Can fix this problem?
    you must change the channel 5g on the router to channels 36, 40, 44, 48, 52 or 56 ..
      YES!!!!!!!!!!!!! work...
      Is possible fix this bug for all chanel?
        that is not the problem .. in fact there is no problem .. the network 5g broadcasts in several bands, and usually the TV boxes and others only work in one .. in this case the U-NII-1.
          https://es.m.wikipedia.org/wiki/U-NII
          OK thanks! Is there any way to show all the channels? thank you!
