S95 TV Box - S905X2 Quad Core, Android 8.1, 2.4G + 5.8G WiFi
    The S95 TV box enables UHD 4K video playback at 75Hz, it has a new VPU with TruLife 8th generation that integrates specific hardware to encode and decode H.265 and VP9 codecs, providing a clearer picture. The box powered by the SoC of AMlogic S905X2, a new Quad Core chip that reaches up to 2GHz and integrates a new and powerful ARM Mali-G31 MP2 GPU. It is equipped with 4GB of LPDDR4 RAM and 32GB of eMMc storage memory that can be extended up to 128GB via the microSD card slot. The S95 box delivers improved performance and responsiveness much faster thanks to the Android 8.1 operating system to provide you with an ultra-smooth and fast running experience and access to great Apps for work and play. It supports dual-band WiFi, which works on both 2.4GHz and 5.8GHz frequencies, offering superior qualities for the WiFi signal.
    Product Features:
    ● Android 8.1 Version
    The all-round upgraded Android operating system with better WiFi siginal than previous version.
    ● High Operating Speed
    S905X2 quad-core CPU can give you high-speed feedback and smooth response.
    ● High-Level Configuration
    4GB RAM and 32GB ROM flash provide enough room for installing apks, games, etc.
    ● Unique Stylish Design
    Small, sleek and has a tiny footprint, can fit in a small space near the TV.
    ● Individual Customization
    Ingenious app installation option through the browser that allows individual customization in a super easy way.
    S95 Android 8.1 TV box is a fantastic device designed for the absolute enjoyment of the Android interface, the equipment is in a quadrangular box of plastic that looks extremely good and elegant: https://gearvita.com/s95-android-8-1...-32gb-rom.html
    Recommeded products:
    xiaomi mi box s tv box global version
    huawei honor band 4 running version
