ENTER-key external keyboard fix
    In some apps like internet or file browser the "enter-key" doesnt work on
    ext. Keyboard.
    So heres the solution:
    (you need root to fix it !)
    open (with a root file browser):
    system/usr/keylayout/Generic.kl
    and set "key28" to "ENTER" (key28 ENTER)
    also open:
    vendor/usr/keylayout/Generic.kl
    and set "key28" to "ENTER" too....
    flashable zip-file (TWRP)->
    tested and working fine now for me.....
    Thanks.
    I solved installing "External keyboard hardware" sw from Google play store
    It has an option
    In advanced setting - > keyboard mapping - failsafe mode - > on
    To trick it. No root needed.
    The demo version occasionally print a demo caracter instead on the current one. Not a big deal.
    My average temperature is 42?C but the 4 cores often run at maximum speed 1,8GHZ and the console get stuck for a couple of second with every application. Does it happen to you as well?
    Last edited by zionthelion73; 24 May 2019, 11:16. Reason: Added quotes for clearness
      ok, facing issues with airmouse mx3 and OK button...is this related?
        dont know about airmouse, just give it a try..
            but where is difference between e.g. keylayouts/Vendor_0c40_Product_7a18.kl and remote.conf?
              keylayouts is for external bluetooth keyboard.
              remote.conf is for the IR remote.
                I know, but what about dongle input devices? same as bt keyboard?
                  yes, the same.
                  i have a dongle keyboard and it works for me...
                    Originally posted by zionthelion73 View Post
                    Thanks.
                    I solved installing external keyboard hardware sw from Google play store
                    It has an option
                    please tell Google play program name for download
                      Solved installing "external keyboard hardware" sw from Google play store
