[ROM] POISONATV S905W NEW V3 [20190307]
    POISONATV
    The Team has done a new Version of the PoisonATV Firmware.
    Changelog:
    -Based On Tanix Firmware
    -Twrp recovery installed
    -OTA App Added
    -Zoomtak Box support added
    -Added ability for camera support
    -Black & White Theme
    -Some little tweaks to improve speed
    -Updated Google Apps
    -Unrooted use Magisk if needed
    Bugs???
    You tell me
    Tips
    -First boot is loading all the scripts so if you encounter slower speeds and playback issues it's because of that, the second boot will fix all this.
    (Must go through setup first and leave running a few minutes before second boot)
    -Front display patches need to flash through TWRP 1st way is to go to settings/about/systemupdate
    select your zip and choose update ....2nd way is terminal emulator .... reboot recovery then enter and will boot into recovery
    THE PROJECT
    Poison is a community project that aims at giving users the best Android TV experience possible.
    Currently we only support AMLogic based devices but we are working on branching to other chipsets.
    So enjoy the cleanliness, optimized and powerful feel of Poison!
    Project developers are Ricky Divjakovski, Whiteak, Minixfreak and Neomode.
    DOWNLOADS
    All Downloads can be found here
    Under the Download for Version 3, you find the generic S905W Version and the special Builds for Zoomtak, Sunvell, Nexbox.
    SUPPORT
    Firmware specific support will be here in the Thread
    DONATION
    You can contribute to the project by donating at PayPal.Me/PoisonDevelopers
    If you would like a custom built firmware we are able to do this, email [email protected]
    SCREENSHOTS
    Coming...
    Good day! Is this the same firmware or with corrections of known problems?
      Is new Firmware with fixes.
      Neomode
        Working excellent on a Tanix TX3 Mini. Just a couple of questions.
        1) Most Tanix firmware have a rainbow screen problem when playing video from time to time (random), or will freeze when playing video with sound then repeating. It as if the video driver crashes or has problems. What version of Tanix software is this based on? Does it have these issues?
        2)As its based on Tanix firmware, the front LED screen just says boot all the time. Is there a LED patch for the Tanix TX3 mini? Ive checked the Mega download share and it doesnt seem to be listed.
        3) Are there any plans to develop a non ATV version with standard playstore?
        Thank you for the amazing rom. Well done!!
          Thank you for your work!
          I already installed on Tanix TX3 mini.
          After I installed TX3_Mini_Clock Display Patch (from original Poison ATV repository) the clock looks upside down.
          Could you fix the patch? (or the ROM?)
            Looks like a new version (V4?) here:
            Build date: 3/14/2019
            Grabbed the link from Youtube, MXQ Project: https://www.youtube.com/watch?v=90DVg4AyiGY&t=31s
            Unfortunately the
            TX3_Mini_Clock Display Patch is not working. Clock upside down.
              Yes there is a new Build.
              We tested and will release it today.
              Neomode
                Thank you!
                Could you fix the Tanix TX3 mini clock patch too?
                  Looks like Mega link folder has been removed??
                    Yes, we doing small fixes.
                    Regards
                    Neomode
                      The thread will be closed, new Version is out.
                      Please go here:
                      POISONATV Here we go with a new Version of the PoisonATV Firmware. We are supporting S905X, S905W, and S912. This Thread is about the S905X Version and only this Version will be supported in this Thread. CHANGELOG -Based on Tanix Firmware -Root access (on or off) -Removed more settings (Useless for AndroidTV) -Twrp recovery
                      Neomode
