Flydigi X8 Pro Game Controller - Double Wireless Modes, All Platform Adaptation, Flymapping Button, Motion Sensing Shooting
    Are you looking for a titanic gamepad capable of supporting wireless connection with a variety of smart devices? Flydigi X8 Pro wireless gamepad is a more than interesting alternative for those looking to play on smartphones with the game comfort offered by a gamepad with 2 joysticks, button mapping, crosshead and triggers.
    Making use of the integrated Bluetooth 4.0 connection, you can pair your Android or iOS phone to play the catalog of the device available in the store, placing the mobile in the removable and folding support that includes the package to turn it into a portable console. By including a 2.4G USB Dongle receiver, the remote also supports wireless connection to Windows computers, tablets, smart TV and Android TV.
    From mobile to tablet, from tablet to computer, so comfortable and practical. You can play on the bus with your mobile, play big on a smart TV or play the PC catalog with a single command. The correctly optimized 300mAh battery offers up to 80 hours of play with a full charge. As professional competition controller, less than 6ms delay, the Flydigi X8 Pro features high sensitivity and accuracy in overall performance.
    Product Features:
    ● Wireless Transmission
    Compatible with Android 4.4 or above devices and Window 7 or above PC, connected by Bluetooth 4.0 or 2.4GHz wireless USB receiver dongle.
    ● Motion Sensing Aiming
    Built-in 6-axis gyroscope acceleration chip provides great motion sensing control and enables air mouse mode.
    ● Flymapping Button Mapping Technology
    Flymapping function is developed based on button mapping technology, enables you drag button to adjust button position, makes the experience more smooth and convenient. Describe 120 points of high speed mapping per second, quick response to small changes of stick angle.
    ● Flydigi Utool
    No need root for Android phone, with the included Flydigi Utool, connecting the power for 10 seconds to activate button mapping. Then you can play any mobile games with controllers.
    ● More Buttons
    Has 3 function buttons more than other normal controllers, left and right triggers are used with mouse microswitch, enable you get higher shooting speed in FPS games.
    ● Dual-vibration Motors
    The left and right grips adopt built-in asymmetric motors and using Japanese ALPS rocker, more realistic vibration feedback can be easily and fully experienced in racing, sports, shooting and other games.
    ● Battery Power
    Equipped with Nordic 32bit Bluetooth chip, special for esports keyboard and mouse. Switch seamlessly between Bluetooth 4.0 low power mode and 2.4G wireless mode, the delay is less than 6ms and the built-in 300mAh polymer lithium battery lasts for 80 hours in normal condition.
    ● Ergonomic Design
    Comfortable and exquisite stripe texture on the surface, anti-sweat, anti-slide, with better hand feel.
    This Flydigi X8 Pro Bluetooth wireless joystick gamepad is designed to bring you brand new gaming experience. The detachable bracket makes installation more easier and reduce the head weight which make it comfortable to play games and it is widely compatible with 3.5~6.8 inch Android smartphones: https://gearvita.com/xiaomi-flydigi-...ontroller.html
    Other good products worth buying:
    lenovo k5 pro
    xiaomi mini flashlight
