Backup XBMC
    Backup XBMC
    If I was to backup the following directory & all sub directories
    sdcard/Android/data/org.xbmc.xbmc
    Would I be able to transfer all of my XBMC settings ((addons, skins, shortcuts etc) and restore again if I flashed another ROM?
    Or - is there an easier way?
    Live as if you were to die tomorrow. Learn as if you were to live forever
    There is an official XBMC addon that you can enable that allows it to back-up all settings etc, such that if you install another version of XBMC or even on another device, you can restore everything from there.
    It's called XBMC Backup.
      Nice one .. cheers
