Elephone is aiming at the younger users with the Elephone A6 Mini as it features a modern design and affordable price.
Limited Time Offer: $99.99
Time: March 11 to March 18
First 10 units daily
More information: http://bit.ly/2UtZPOA
Besides the clean back cover look, the front panel hosts a waterdrop notch that takes up much less space than the classic notch introduced by Apple on iPhone X. The notch is needed for the 15MP selfie shooter to fit and at the same time maximize the screen/body ratio. On the back, there is a dual camera setup with 16MP/2MP sensors. The smaller one is used to measure depth for producing the Bokeh effect.
The A6 Mini will come with the MTK6761 SoC accompanied by 4GB of RAM and 32GB of storage. The 3180mAh battery should take you through a full day as the smaller than usual 5.71″ display in conjunction with the low power usage SoC are a quarantee for that. So, if you are on the hunt for a good looking and powerful enough phone, the Elephone A6 Mini could be the one for you. The device will come with Android 9 Pie .
Currently, the Elephone A6 Mini has been sold in coolicool, only need $99.99.
