Sunvell T95Z Max TV Box - Experience The Real Color in The World
    Sunvell T95Z Max TV box is equipped with Amlogic S912 Octa-core ARM Cortex-A53 CPU up to 2.0GHz. Ultra high frequency, more than 4 times performance improvements. 2GB RAM provides higher running speed without buffering or breaking down, 16GB ROM supports external hard drive, ensures enough room to download your favorite APPs, never worry about running out of space.
    It runs on the fast and powerful Android 7.1 OS which has a better compatibility of software, games and APPs. Supports 4K resolution and H.265 VP9 decoding, not a single detail will be missing while you enjoy all your favorite movies. It also supports hardware 3D graphics acceleration, provides you extreme vivid feeling when playing 3D games.
    Product Features:
    ● Android 7.1 operation system
    ● Amlogic S912 CPU, Cortex-A53, octa-core, 2.0GHz
    ● Mali-T820MP3 GPU
    ● 2GB RAM + 16GB ROM
    ● HDR for 4K ultra HD images
    ● 2.4GHz + 5GHz dual band WiFi
    T95Z Max supports 4K resolution, offers you finer and smoother pictures. You can view every single detail on the picture, and experience the real color in the world: https://gearvita.com/sunvell-t95z-ma...-16gb-rom.html
    You may also like:
    samsung evo plus micro sd card
    xiaomi mi pad 4 lte
