installed PMID10C_MODIFIED_STOCK.img working except for CWM
This rom is working fine, but when I reboot to recovery I can not see the internal SD or the external SD card and it corrupts the tablet (it messes up the partitions after it runs). I am going to install a newer version from here: http://dl.xda-developers.com/attachd...ation=C0A83A25
as it has the ability to "side load" the zip packages.
But what partition /dev/block/nand? do I write the image to? I don't know that I trust the installer which writes the file to /dev/block/nandg as the Polaroid images tend to be different than other tablets out there...
Domenic
the link did not work error; 410-Gone
Reason: add
I ended up trying it and it works great. If you want to install any zip files you need to select install from internal sd, or you can side load the files with adb. The Menu button moves the menu selector down and the power button selects it.
I have been playing with cm10 for A10 devices and have been attempting to build a compatibility zip file with no avail. Any one tried cm10 for any of the other a10 polaroid devices?
