Lilliput-001 1080P IP Camera - Get Everything In Sight
    This Lilliput-001 1080P IP camera features HD 1080P display image and recording resolution. It is equipped with 2pcs array IR LED and IR-CUT double filter, provides with good day and night vision. It is also with functions of motion detection, two-way audio monitoring, and phone APP control, etc., can remotely viewing by PC client, phone APP, and mobile devices anywhere at any time.
    Product Features:
    ● 1080P full HD videos, 2MP photos, never miss any detail.
    ● No dead zone with PTZ gimbal, has a 355-degree ultra wide angle of view.
    ● 15m night vision with two high-quality IR-cut sensors for 24h surveillance.
    ● Built-in microphone for voice call.
    ● Remote access of up to 6 devices supported simultaneously.
    ● Motion detection within 10m and real-time alarm to protect your property effectively.
    ● Insert a 64GB microSD card for 12 days recording, neither need to delete the old videos nor format the microSD card.
    ● IP66 waterproof, suitable for more indoors and outdoors environments.
    ● Audio identification technology can identify baby crying and send "Baby Cry" alert message.
    ● Support real-time monitoring of multiple terminals such as smartphones, tablets, notebooks and desktops at the same time.
    The Lilliput-001 IP camera is designed for home safety and security, the compact design makes it very easy and convenient to install anywhere inside your home. With this surveillance camera, you won't have to be anxious about going outside. You are able to check the house through the mobile phone, which is easy and convenient: https://gearvita.com/lilliput-001-10...amera-2mp.html
    You may also interested in:
    mijia 1080p ip camera
    honor honor band 4 running
