Only 500 Pieces Latest Model
● Android 8.1 Version
Based on the Android 8.1 OS, with fast speed and smooth performance, which is designed to turn your regular TV into a smart one.
● DDR3 2GB RAM, eMMC 8GB ROM
It is configured with DDR3 2GB RAM, and eMMC 8GB ROM, thus it can provide enough room and freedom to install Apps without worrying about running out of space.
● Voice Remote Control
Xiaomi Mi Box S will search for what you want by speaking to the remote.
● DTS-HD and Dolby Stereo Sound
Processed by Dolby audio and DTS-HD audio encoding, let you fully enjoy the 3D premium sound quality and cinema effect at the same time.
● HDMI 2.0 Connector
You can go directly to let your TV and Mi Box S connect through an HDMI cable and set up your home cinema for the best 4K x 2K UHD multimedia experience.
● High Clarity 4K HDR
Features the latest 4K HDR technology and high-speed 4K processing, up to 60fps playback, giving ultra high-definition and lifelike visual experience
● Access Tons of Content
Compatible with various apps, giving you access to tons of superior video, services and a constant stream of fresh new content
Gearbest
