Beelink Gemini X55 Ultimate Mini PC - Pentium J5005, 128GB MSATA SSD, 2.4GHz + 5.8GHz WiFi
    Beelink Gemini X55 Ultimate Mini PC with Pentium Silver J5005 Quad processor up to 2.8GHz that integrates 8GB of RAM and 128GB of MSATA SSD. Manufactured in 14nm, these processors are suitable for office environments, web browsing, play 4K multimedia content or simply game playing. The RAM memory is the DDR4-2400 type, while the storage, an MSATA port and a SATA 3 connector are available for mounting a 2.5-inch disk.
    Faster WiFi is something we all crave. Fortunately, it's also something you can have on the Beelink Gemini X series, even on a budget. The 802.11 b/g/n/ac 1?1 MIMO and Bluetooth 4.0 combo module and Gigabie Ethernet solutions are all implemented to accomodate even the most demanding use cases - transferring files between devices in your home or office, streaming video from a network-attached drive to a television, and gaming with the lowest network latencies possible.
    Product Features:
    ● Intel Gemini Lake Pentium J5005 Processor Quad Core, 4 threads 1.5GHz up to 2.8GHz 4M cache.
    ● Intel HD Graphics 605, up to 800MHz.
    ● LPDDR4 8GB RAM + 128GB SSD MASTA, expandable 2.5-inch HDD.
    ● SATA port and TF card slot, multiple ways of capacity expansion.
    ● 2.4GHz + 5.8GHz dual-band WiFi and 1000Mbps Ethernet, fast and stable network access.
    ● Built-in fan provide a powerful heat dissipation system to ensure high performance operation in high temperature.
    ● Support Windows and Linux operation system.
    ● Built-in 240mAh lithium-ion battery.
    ● Dual HDMI dual screen display, double office efficiency.
    ● Energy-saving, low power consumption and environment protection.
    With wall-mounted design, it is simple and convenient to install, lets your office environment more neat: https://gearvita.com/beelink-gemini-...e-mini-pc.html
    Greatly acclaimed products:
    raspberry pi 3 model a+
    lenovo z5 pro 6gb ram
