Big deal- Chuwi's HeroBook- super cheap Windows 10 laptop
    If you're on a tight budget, Chuwi's HeroBook could be for you. Aimed at students and "low-income workers", the HeroBook's specs are nothing to get too excited about, but this is not the point of this particular laptop.
    Limited Time Offer: $219.99
    More information: http://bit.ly/2uvMXw9
    What the HeroBook is about is giving users a reasonable experience and above-acceptable hardware for a super-low price. For $219.99 you could kit yourself out with a laptop that is capable enough for day-to-day computing, or could serve as a secondary laptop for travelling with it.
    A 14.1″ laptop similar to the Lapbook SE with 4GB of RAM and 64GB of storage. Called the Herobook, it has a large touchpad and full-sized keyboard like the Lapbook SE?s. The HeroBook has a 38Wh battery so paired with the older Z8350 should be good for 9-10 hours even. It has USB 3.0, USB 2.0 a MicroSD card reader, 3.5mm jack and D/C charging.
    Chuwi promises 9 hours of life from the battery (or over 9 hours, or 7-8 hours depending on where you look on the website!), and weighing in at under 2KG, it's ideal for chucking in a bag when you hit the road. Fast charging means you shouldn't have to wait too long to power up either.
    There's a large multi-touch trackpad, and a full-sized keyboard for comfortable typing. In terms of ports and expansion options, you'll find an M.2 SSD slot, MicroSD slot, two USB 3.0 ports, a 3.5mm headphone jack, and a micro HDMI port for hooking up to an external display.
    Coolicool is now offering a discount for $219.99.
    Coolicool - Located in China and a trusted seller on Freaktab. We are selling loads of Android TV Sticks, Tablets, Smartphones and consuming electronic merchandises to all over the world. We have local Warehouse in Europe that our customers can get what they want in 72 hours(2-5 Days Delivery&No tariff).
    Lowest Price Guarantee
    Easter Special Offer!
    Link: http://bit.ly/2Iy2Av4
