I just got a Polaroid S10 tablet from Kohl's (which I may or may not keep). It's running JB 4.2.2, and I was wondering if anyone knows of any root exploits that will work with it.
Polaroid S10...root???
Originally posted by AndroidPizza View PostHey guys,
I just got a Polaroid S10 tablet from Kohl's (which I may or may not keep). It's running JB 4.2.2, and I was wondering if anyone knows of any root exploits that will work with it.Freaktab Rom Developer
Originally posted by shaunmt View PostWhat else can you tell us about it?
Re: Polaroid S10...root???
Here's some specs, straight off the box. Even the worthless info.
OS: Android 4.2.2
Processor: 1.6GHz, Dual Core
RAM: 1GB/DDR3
Screen Resolution: 1024 x 600
Internal Memory: 8GB
External Memory: Micro SD
Networking: Wi-Fi 802.11 b/g/n
Battery: Rechargeable Li-ion Polymer
Sent from my Atrix HD
Check out this thread!AndroidPizza
And my hunch is that it has an Allwinner processor.
Root S10
Rooted it by downloading from 1MobileMarket SuperSU ver. 1.65 and then installed Google Services and Google Playstore apks.
Hope this helps.
Originally posted by jimwallcft View PostJust replaced my 701C [a wonderful cheap tab thanks to Electrik's newest rom - because the usb port connection broke] with an S7. Great improvement over the 701C. Just ordered another one at $75 for **** to give the wife to replace her beat up 701C.
Hope this helps.
Originally posted by AndroidPizza View PostWait...you mean it's rooted out of the box? You just need to sideload a superuser app?
firmware update for google store at www.southerntelecom.com/polaroid support (from polaroid company)
you can upgrade to have google play in polaroid website..they only offer this for A8, S7, S8, S10.
so, you don't have to root the tablet. it is compatible to have google play store...
and.. it is firmware update. you will notice big difference after this update.
first, you should go to the site below to download file to desktop or laptop computer.
then, follow this instruction below. they only have instruction for A8 but it's same anyway.
be sure to follow every steps.. this update comes with google map, google+, etc..
good luck~!
Originally posted by creanity View Post-------------------------------------------------------------------------------------------
good luck~!Polaroid S8
Blackberry Torch
Kindle Fire HD Gen 2 - Wifes
Nokia 520 Windows 8 - Wifes
(3) Nextbook 7s - Slooooooow - (Finless Bob ROM) - used for kids e-readers
(2) Samsung Exhibits - kids
Samsung Blaze, Kindle Fire, (2) PMID701c (Elektrik ROM) - all RIP
...some laptops, some PC's and some routers / switches
FYI, here is an Antutu screen shot (of what I COULD get).
Fresh out the box, no mods yet. Antutu and Superuser / SuperSU won't run, I can't get to root with ES File Explorer, etc, etc, etc, so maybe they changed something with the root access?
Here are some screen shots (build looks like August 27, 2013?)Polaroid S8
Blackberry Torch
Originally posted by jsta6 View PostFYI, here is an Antutu screen shot (of what I COULD get).
Root S10
Download the new software update from Southern Telecom as it contains Google Play
and flash the tablet. Be sure to save anything you wish to keep as this update will erase the tablet. Then follow directions from link below:
http://www.freaktab.com/showthread.php?8478-How-to-root-Polaroid-S8-S10-gt-TUT-lt
Originally posted by AndroidPizza View PostAnyone have any ideas on how to obtain root on the new "Google Play" firmware?
There are currently 1789 users online. 1 members and 1788 guests.
