Intel HD Graphics 600 / Expandable 1TB 2.5 inch SSD HDD / 2.4GHz + 5GHz WiFi / 1000Mbps / 2 x USB3.0 / BT4.2
GLK-UC2X is the latest mini PC released by Pepper Jobs. Powered by the latest generation of Intel quad-core processor, GLK - UC2X comes with the latest generation of hardware video decoder and is able to decode 4K VP9 and H. 265 contents. Featuring dual USB-C ports, Gigabit Ethernet, fast 802.11ac WiFi and Bluetooth connectivity and a silent heat pipe cooling system, GLK - UC2X aims at delivering the maximum performance out of the Gemini Lake processor without any performance loss. GLK -UC2X supports up to three 4K 60Hz display outputs simultaneous which makes it a perfect solution for low-power UHD media center or office computer.
Main Features
●Intel Gemini Lake N4100 CPU, Quad Core
Low-power desktop platform processor, stable and reliable performance, less delay and lag.
●Intel HD Graphic 600 GPU
Better and faster in playing games and watching videos than the previous generation. Meet your requirement for high resolution and give you an enjoyable entertainment experience.
●4GB DDR4 RAM for Advanced Multitasking
Allow your PC to run at higher speed. It could deal with multiple task and windows easily at the same time.
●64GB EMMC Storage Capacity
Provides enough capacity to store pictures, videos, music and more.
●Good Heat Dissipation Performance
Built-in heat pipe ensures efficient and rapid heat dissipation. Energy saving, environmental protection, and low power consumption.
● Gigabit LAN and 2.4GHz+5GHz WiFi, easy to access network
● Rich interface, support multiple devices connection
● Small and light, easy to carry, and stable in performance
Gearbest GBCNPPJ01 saves $30
