What should I do now?
Cannot flash my Jesurun DX05
I have some problems with flashing my device. I connected it to PC and installed adb driver, but RK Flash tool does not see it. ROM_Flash_Tool_137 does not see it too. I tried on 3 PCs with Windows 7 (both 86 and 64), 2 different usb cables and effect is the same.
What should I do now?Tags: None
Upd. Problem was probably solved by console command "adb reboot bootloader". After rebooting and installing additional driver RK Flash tool saw the device and firmware 2.0.4 was installed. But after that PC don't see the device at all. I don't have the TV near to check, either it installed successfully and I only need to switch "USB debugging" and "Connect to PC" on in settings menu, or I eventually bricked the device. I could check it only in the evening when I will return home.
Upd2. Flashing was successful, problem solved.Last edited by Brenwen; 03 October 2013, 18:02.
Originally posted by Brenwen View PostUpd. Problem was probably solved by console command "adb reboot bootloader". After rebooting and installing additional driver RK Flash tool saw the device and firmware 2.0.4 was installed. But after that PC don't see the device at all. I don't have the TV near to check, either it installed successfully and I only need to switch "USB debugging" and "Connect to PC" on in settings menu, or I eventually bricked the device. I could check it only in the evening when I will return home.
can you explain me in details what you did? I am unable to recognize my unit as well.
tks
Download actual USB drivers for windows for example at Tronsmart ("Class for rockusb device") or geekbuying.
1. unplug all cables from device.
2. plug micro usb otg cable into device and into pc (nothing else)
3. press and hold little restore button on which is under device
4. plug in power cord (remember to still hold restore button) and you are in flash mod
5. on first time it may not work before driver are installed but later its working every time.
Run flashtool as administratorRK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostDownload actual USB drivers for windows for example at Tronsmart ("Class for rockusb device") or geekbuying.
The mode by "press and hold little restore button on which is under device" needs other drivers (windows 8.1 drivers at the moment not availible) than debug mode at normal startup...
Or does the windows don't recognize any unknowing device at that moment, if it so, I don't have any idea (perhaps the cable?)...RK3288 Devices
Originally posted by no_spam_for_me View PostThe mode by "press and hold little restore button on which is under device" needs other drivers (windows 8.1 drivers at the moment not availible) than debug mode at normal startup...
Or does the windows don't recognize any unknowing device at that moment, if it so, I don't have any idea (perhaps the cable?)...the pc cant find the driver on recovery mode.
I'm not sure, if I understand your problem, but
Originally posted by alexjcgdf View Postthe pc cant find the driver on recovery mode.
With windows 8 there is eventually a problem because of "unsigned" problemRK3288 Devices
Originally posted by Brenwen View PostIf you have all drivers installed, but device don`t reboot into bootloader mode, you must unpack this archive with adb file into any folder and then start windows console (start>search>cmd), go to this folder (if you unpacked it into c:\RK3188_ROOT you should enter "cd c:\RK3188_ROOT"), then enter "adb reboot bootloader". Device will reboot into bootloader mode, additional driver will be installed and flashing software will see the device so you could flash the firmware you need.
The .rar file has a password. Can you tell me what it is?
tks
Originally posted by no_spam_for_me View PostI'm not sure, if I understand your problem, but
couldn't work, because windows cant find the driver automatically, because you have to use manual selection of the correct folder (x89 vs. x64 and then correct OS-Version) during the driver installation...
Originally posted by alexjcgdf View Posteven forcing it it just doenst work. the windows sais that the driver isnt right for it and it cant start the hardware. I think the driver isnt right for it.
if not, try to add it in the inf ....
[Rockchip.NTx86]
[Rockchip.NTamd64]
OR
you have to ask your trader to get the correct driver for bootloadermode (NOT Debug Mode, because that works for you, if I understood it correct)RK3288 Devices
Have you look inside our device to confirm witch pcb do you have?
(becauseK-R42 3.1 PCB)RK3288 Devices
Originally posted by no_spam_for_me View PostHave you look inside our device to confirm witch pcb do you have?
There are currently 2590 users online. 0 members and 2590 guests.
