First open box and glue little fan on radiator.
Connect cable + to usb 1 or 2 on PCB and - I first connect to power supply, but fan work even torn off box.
When connected to usb, fan stopped rotate when diode is red, and it's silent now.
If you want little clean point light diode red and blue u needed put on diode more termo pipe.
I do many little holes on the cover and now hot air go up, temp is 37C.
Without holes is 55C.
I play You Tube movie full hd to test, and I have
50-53 degree C, after 73-82. Oops.
Fan 20x20mm ♨️⬆️ air flow up.
Wysłane z mojego Redmi 4 Prime przy użyciu Tapatalka
