This firmware works with MECOOL KIII PRO TV BOX
MECOOL KIII PRO Android 7.1 3GB/16GB TV BOX Firmware Update 20181221
Originally posted by Freddydq View Post
This firmware works with MECOOL KIII PRO TV BOXCoupons Updated Every Day: https://bit.ly/2RnbHUi
Originally posted by charmed View Post
the Solution is here.
Steve
**SOLVED** I have a KIII Pro with dual (DVB-C/S/S2/T.T2) tuner. I faced this “No LICENSE” problem when i flashed the latest firmware i.e. KIII_PRO_AVL6862-NHG47L-20181221.165922.V0213.img. As a result, when I scanned channels using the DTV app, I would get ” NO LICENSE” on all channels. I was able to locate an older DTV app + recovery (dtv_20180820_twrp.rar) from some forum. I flashed recovery & then flashed the dtv app using the TWRP recovery and the “NO LICENSE” problem was solved. Also, I have now all the 3 options: DVB-C , DVB-S/S2, DVB-T/T2 in the scanning options.
LINK:
aHR0cHM6Ly93d3cuZHJvcGJveC5jb20vcy9iamg4YTY0NWJ2a2 dldnkvZHR2XzIwMTgwODIwX3R3cnAucmFyP2RsPTA=
Decode the above using base64decode[dot]org and use the link to download the RAR file. Extract recovery and twrp, Flash recovery, then go to recovery and flash the dtv zip. Restart KIII Pro and all will be good to go.
Good luck
Steve
**SOLVED** I have a KIII Pro with dual (DVB-C/S/S2/T.T2) tuner. I faced this “No LICENSE” problem when i flashed the latest firmware i.e. KIII_PRO_AVL6862-NHG47L-20181221.165922.V0213.img. As a result, when I scanned channels using the DTV app, I would get ” NO LICENSE” on all channels. I was able to locate an older DTV app + recoverycan (dtv_20180820_twrp.rar) from some forum. I flashed recovery & then flashed the dtv app using the TWRP recovery and the “NO LICENSE” problem was solved. Also, I have now all the 3 options: DVB-C , DVB-S/S2, DVB-T/T2 in the scanning options.
LINK:
Good luck
When I click on "Restore user data" nothing happens !!
Originally posted by GeekBuying_Rep View Post
Hi friend,
Sorry for inconvenience.
Please kindly send us the MAC address of it.
We will check it.
There are currently 8775 users online. 7 members and 8768 guests.
