damaged USB
    damaged USB
    Hello All
    I need a little help, I need to replace a USB female Jack, but I cannot find the same one anywhere, I have put some pictures up for you to look at?. The only markings on the USB I can see are the word ALLTOP and the number 1636 ?so any help identifying the make or the manufacturer so I can buy a couple would be much appreciated
    Bazza0803
ID:	767991Click image for larger version
ID:	767993Click image for larger version
ID:	767994Click image for larger version
ID:	767995Click image for larger version
    You could attempt to retrofit something like this depending
    Or this ?
    Global Direct Parts offers a huge catalog of OEM wireless replacement parts for repair shops, schools and end-users including Apple, Samsung, Chromebook and many other manufacturer parts.
      This part came from an Acer Laptop, if I recall correctly. Looks very similar to yours.
      Maybe you can locate a used one on fleabay.
      Are you in the US?
        Or this ?
        Hi Trebor I afraid that one is no good it is on top of the plate which would not line up with the case.. The other one you mentioned?.the back locating pins need to be in line with four data pins, very near but no good
        thanks anyway Mate
        • trebor
          trebor commented
          Editing a comment
          I was thinking just 4 wires and double side tape it to get ya going, hanging of the outside
        Are you in the US?
        Hi Riscy Dude thank you as well for your help that one looks very promising, I will try and find out where I can get a couple from, I live in London England
        Barry
          Hope you find what you need. I would have sent it to you if in the US, but shipping to London would be prohibitive.
            Ok Riscy thank you for your help
