Can you help me with this device? I can't figure out how to change the stock firmware, because the stock one is laggy and poor as hell. What have I tried at the moment:
1. Flashing with USB Burning Tool. Different versions of software, different firmwares, different ways to start the firmware process (connect - import img - start; import img - start - connect), with AC adapter and without, holding the reset button whil starting th process and unholging it - all I get are these two errors:
[0x10105004]Romcode/Initialize DDR/Read initialize status/Error result
[0x00101004]Erase bootloader/Lowper/Identify/Error result
2. To restore from backup from T95Z Plus (pretty similar box by tech specs) through TWRP; the last can't see any backup on otg-usb at all;
Really tired of this box. As I can see, it just can't get into the right mode for firm-waring process. The box is recognised by PC even without the reset button is being pushed! It's not yet bricked so far, I even managed to restore from my initial backup. But I'm getting tired of these little piece of plastic.
Could somebody provide any help?
