The U Pro is the first Elephone smartphone to use a high-end Qualcomm processor. It is equipped with a Snapdragon 660 SoC. The Elephone U Pro, formerly known as Elephone S9, looks exactly like the Elephone U. It comes with a 3D glass back and a 5.99-inch AMOLED screen with Full HD resolution. The phone comes with either 4 64GB or 6 128GB and is running Android 8.0 Oreo out of the box.
Limited Time Offer: $199.99
More information: http://bit.ly/2WK7fxR
The curved touchscreen of the Elephone U Pro looks similar to one of the Samsung Galaxy S phones. The mobile has a curved 2.5D 5.99-inch AMOLED display with a resolution of 1080?2160-pixels (403ppi). In addition, the screen is protected by Corning Gorilla Glass 5 and supports 10-point multi-touch.
The Elephone U Pro is powered by a 64bit Qualcomm Snapdragon 660 octa-core processor with a maximum clock speed of 2.2GHz with improved performance and power consumption compared to the Snapdragon 653. The device is available in two variants ? 4GB RAM and 64GB internal storage, and 6GB RAM and 128GB internal storage. Thanks to a hybrid SIM slot the storage can be further expanded.
The Elephone U Pro is a triple camera phone. On the rear is a dual camera with two 13-MP sensors. One is responsible for taking RGB pictures and the other for monochrome. The rear camera supports Phase Detection autofocus (PDAF), Bokeh effect with ArcSoft algorithm and has a dual-tone LED flash. The video recording resolution is 4K with 30fps or 2K with 60fps. On the front is an 8MP front-facing the camera for selfies and to unlock the phone with your face (FOTA later).
In terms of connectivity, there a minor difference compared to the Elephone U. The dual SIM phone supports connectivity options such as dual-band Wi-Fi, Bluetooth 5.0, Qi Wireless Charging and NFC are included. The high-end version packs a 3550mAh battery which should even last longer than the 3620mAh battery of the Elephone U because of the more power efficient Snapdragon SoC. The Elephone U Pro runs Android 8.0 Oreo out of the box.
You can find this amazing Elephone U Pro (6 128) in the CooliCool.com at a price of $199.99 only 100Pcs from 8th April to 12th April with an incredible discount.
