H96 Pro+ Problems
    H96 Pro+ Problems
    Hi Folks, i?ve got several Problems with my H96 Pro+ runnung at Android 7.
    1st the Hdmi Cec don?t switch my Philips Tv on, only off
    2nd my Wifi Remote Control don?t work permamently, i can use it a long time, than i power of my Device und reboot, than the Remote won?t work anymore. I have to take out the usb dongle, and put it in again, than everything works fine
    Is there a better firmware to install at the Device?
    Lack of information! How is she the motherboard, blue, black, or green?
    The following firmware is for green motherboard only!
    I also had problems with this box. Namely with on / off. I uploaded into this box compatible Minix firmware and everything works. You can try.
    https://drive.google.com/uc?id=1OShA...xport=download
      Is there a way to get to this information without taking the backpanel of?
        I have a H96pro+ with a green motherboard, 3gb RAM, 32gb ROM. It's stock with Android 7.1.
        The sticker on the mb says cz-s32-v2.2.
        Some features don't work well & Pluto TV is buggy.
        Can someone direct me to an upgrade path?
          For your green motherboard is the best firmware in the title with:
          KDMC or Mac and others, NOT LP!!!!!!
          However, all the old bugs were transferred to the new firmware, so the result is questionable.
          Probably the best for your box is:
          aml_7.1_s912_q9377-H96PROPLUS_KDMC_mac-20170809
          You can also use the above Minix firmware.
            Hope you can help me out
              Now i?ve got an Problem. I upgrade the Box with the Firmware above. For a few Seconds the Display said upgrade, but now nothing else is working. Black screen, no power Led at the front. Help...
              -- edit the box is alive again. found the stock rom and reinstall it. that works for me. that firmware https://drive.google.com/uc?id=1OShA...xport=download won?t work for me. how can i see if i?m on a ddr 3 or ddr 4 model,the sticker on the mainboard doesn?t have that information
                You should have waited, it would turn everything back on.
                If not, put the firmware there:
                  At this moment i?m on aml_7.1.2_s912_q9377-H96PROPLUS_mac-20171120.7z
                    So which firmware do you think should be the best at this moment for my model?
